sadhu 38 Posted September 4, 2019 Hi. Need help ! I am instancing redshift proxy object (Human character with primitive groups like shirt, pant, skin.. etc ) using "instancefile" attribute and using stylesheet to render it. I am not able to access subtargets and randomise any material parameter (like randomising basecolor of subtarget shirt or pant). I am able to do this using mantra and stylesheet but similar approach (targets and subtarget) is not working for redshift. In the stylesheet, the Target is set to point instances; I tried accessing primitive groups on the instanced object by adding subtargets to the target but it does not work. Can someone please help me with this. Thanks Share this post Link to post Share on other sites
polvy 17 Posted May 9, 2020 Hi! Did you eventually get the solution to this?? I'm struggling quite a lot with the same problem right now. Thanks! Share this post Link to post Share on other sites
