garf Posted September 10, 2019 Share Posted September 10, 2019 I've created a material and within that I've created a custom opacity map/attribute. How can I get that custom attribute (opacity map) into another material? Quote Link to comment Share on other sites More sharing options...
kfu Posted September 10, 2019 Share Posted September 10, 2019 Don't know how you created this map. If you can't do it in mat content, maybe create the map in sop as readable attribute. Quote Link to comment Share on other sites More sharing options...
davpe Posted September 13, 2019 Share Posted September 13, 2019 based on what do you want to transfer that data? if you wanna raytrace you can use the Gather VOP - it can send rays from object's surface or from point in space and gather surface data from surrounding objects it hits. if that's what you're after... Quote Link to comment Share on other sites More sharing options...
