trevisan Posted September 20, 2019 Share Posted September 20, 2019 (edited) Hi guys, I made this simple sim in Houdini and exported it to C4D to render with Octane V4 as alembic. The problem is that in the first frames, there are those weird polygons on the mesh, maybe normal problems? I didn't manage to fix it so I'm ask if anyone here had this problem before and knows a solution for it. I will attach the render and my hip filie below. Thanks in advance. RnD_Viscous.v0.hip lan_rnd_sorvete.mov Edit: I'm sorry admin I messed up with the replies. Edited September 20, 2019 by trevisan Quote Link to comment Share on other sites More sharing options...
trevisan Posted September 20, 2019 Author Share Posted September 20, 2019 Just now, trevisan said: So guys, I made this simple sim in Houdini and exported it to C4D to render with Octane V4 as alembic. The problem is that in the first frames, there are those weird polygons on the mesh, maybe normal problems? I didn't manage to fix it so I'm ask if anyone here had this problem before and knows a solution for it. I will attach the render and my hip filie below. Thanks in advance. RnD_Viscous.v0.hip lan_rnd_sorvete.mov Quote Link to comment Share on other sites More sharing options...
