trevisan Posted September 20, 2019 Share Posted September 20, 2019 (edited) Hi guys. I recently wacthed Fifty50 tutorial making a infection effect and now I'm trying to mesh the points but I couldn't achieve a better quality result. Btw I'm pretty new to houdini :{ My currently setup after points is Volume Rasterize Attributes> Vdb Smooth> ConvertVdb to polygons. Are there a better way to mesh those points? hip file attached, thank you in advance guys. RnD_Infection.v01.hipFetching info... 001_Pedestal_high_poly.FBXFetching info... Edited September 20, 2019 by trevisan Quote Link to comment Share on other sites More sharing options...
Dweeble Posted September 21, 2019 Share Posted September 21, 2019 What kind of end-result do you want to use the mesh for? Do you want the original geometry's topology? Like this? O6F9b5nQDF.webmFetching info... If so you could boolean the mesh away: RnD_Infection.v01.hiplc That's the old mesh on top of the new mesh. If you get rid of the white section you still have 'nasty' topology wherever the geometry isn't defined (the inside of the column). Not sure what kind of topology you're looking for. If it's quads and perfect edge-loops I have bad news for you :D. Quote Link to comment Share on other sites More sharing options...
trevisan Posted September 23, 2019 Author Share Posted September 23, 2019 Hey Dweeble thanks for your answer mate and sorry for my delay I wanted to achieve a detailed mesh with the growth effect I made. I think your setup with boolean is great and if a export from the Peak node will probably fix my problems I will export is as alembic to Cinema 4D. There I will have a original mesh on bottom and this new one with the growth effect on top of it. I would love to make the whole scene inside Houdini but I can't use Mantra because of render times As you mentioned, I don't need a perfect mesh with edge-loops hahaha. That would be a big problem lol Thank you for your help. It's going to help me a lot man Quote Link to comment Share on other sites More sharing options...
