richnosworthy Posted September 23, 2019 Share Posted September 23, 2019 Hey, anyone had any luck with upres'ing a colour pyro sim in houdini? I'm just using the shelf tools to get something going quick. Colored smoke from my point coloured object works perfectly, but when i up res the container with the shelf tool, i lose the smoke colour - just goes black. Checking the details of the up res dop network, up res smoke object has cd and alpha enabled, the volume source is sourcing Cd as it was in the initial sim, but something not working quite right. If you do the coloured smoke shelf tool and then the up res container shelf tool, you should see what i mean. Anyone got this working? thanks 1 Quote Link to comment Share on other sites More sharing options...
bunker Posted September 24, 2019 Share Posted September 24, 2019 the upres solver hasn't been updated for a while, you'll need to add 3 things: - resize the Cd field - source into Cd - advect Cd (inside the upres solver, the advect_density1 node) hope that helps. 1 Quote Link to comment Share on other sites More sharing options...
richnosworthy Posted September 24, 2019 Author Share Posted September 24, 2019 Helps a lot, thanks for the tips. Will check those out, thankyou Quote Link to comment Share on other sites More sharing options...
bunker Posted September 29, 2019 Share Posted September 29, 2019 Here is an example if you're interested. for the lowres sim, I had to change the "color" Enable Solver DOP, it required Alpha, and I didn't want that. for the upres, I just added "Cd" in the gasAdvect. As a bonus, I added a scalar field name "cdl", it's used to store/set the length of Cd on every frame, it keeps the colors visible for much longer. left: div size=0.2, right: div size=0.033 (6x upres) advect_Cd_bunker_001.hiplc 9 Quote Link to comment Share on other sites More sharing options...
richnosworthy Posted September 29, 2019 Author Share Posted September 29, 2019 Hey thanks bunker, i didn't manage to figure it out so far so this is really helpful. Cheers for setting this up Quote Link to comment Share on other sites More sharing options...
