fragger Posted July 25, 2006 Share Posted July 25, 2006 Hi, I'm having trouble to get the HDK to work (to compile a DSO). I set up all the erv variables and installed the HDK as described in the odwiki article (the windows part) but when I try to compile one of the sample DSOs (for example - I just type "hcustom SOP_Star.c" in the command prompt) I get that message : F:\Program Files\Side Effects Software\Houdini 8.0.474\toolkit\samples\SOP>hcustom SOP_Star.c Making 'SOP_Star.o' and 'C:/DOCUME~1/sam/MYDOCU~1/houdini8.0/dso\SOP_Star.dll' from 'SOP_Star.c' Error running cl Argument list: 0: cl 1: -TP 2: SOP_Star.c 3: -DUT_DSO_TAGINFO="3262197cbf01481903a01f89403d94ee6b108baea501d6a923ff915d530aee8261de65b4ca77695e160aadba72da200a51fbec0affd3f95643062bd277ea81ac5bbe45a0ffd0108ea326de490a90" 4: -TP 5: -DVERSION=8.0.474 6: -DOFSTREAM_PERMISSIONS=, 0666 7: -DI386 8: -DWIN32 9: -DSWAP_BITFIELDS 10: -DDLLEXPORT=__declspec(dllexport) 11: -I 12: . 13: -I 14: F:/Program Files/Microsoft Visual Studio .NET 2003/Vc7/include 15: -I 16: F:/Program Files/Microsoft Visual Studio .NET 2003/Vc7/PlatformSDK/include 17: -I 18: F:/PROGRA~1/SIDEEF~1/HOUDIN~1.474/custom/include 19: -I 20: F:/PROGRA~1/SIDEEF~1/HOUDIN~1.474/toolkit/include 21: -Ox 22: -MD 23: -GX 24: -GR 25: -DSESI_LITTLE_ENDIAN 26: -DMAKING_DSO 27: -FoSOP_Star.o 28: -LD 9: -link 30: /libpath:F:/Program Files/Microsoft Visual Studio .NET 2003/Vc7/lib 31: /libpath:F:/Program Files/Microsoft Visual Studio .NET 2003/Vc7/PlatformSDK/lib 32: 33: F:/PROGRA~1/SIDEEF~1/HOUDIN~1.474/custom/houdini/dsolib/*.a 34: -out:C:/DOCUME~1/sam/MYDOCU~1/houdini8.0/dso/SOP_Star.dll F:\Program Files\Side Effects Software\Houdini 8.0.474\toolkit\samples\SOP> error running cl..what is cl? it creates the output folder but it is empty.. I really don't know whats wrong.. I followed all the instructions PS: I'm running win XP, Houdini 8.1.655 and VStudio 2003 .NET any suggestions what the problem could be? Quote Link to comment Share on other sites More sharing options...
FrankFirsching Posted July 25, 2006 Share Posted July 25, 2006 cl is the C++ compiler of Visual Studio. Make sure, that you have the build environment sourced. I'm in front of a Linux-Box now, so I'm not 100% sure, but if I recall it correctly the command to do this is called vcvars32.bat. It's located somewhere in the Vc7/bin directory of your Visual Studio installation. Quote Link to comment Share on other sites More sharing options...
mtucker Posted July 25, 2006 Share Posted July 25, 2006 I think the revealing line here is "14: F:/Program Files/Microsoft Visual Studio .NET 2003/Vc7/include". You presumably have se the MSVCDir environtment variable (of hcustom wouldn't run). But you need to set it to a valu with no spaces in it. Instead of "c:/program files/...", use the 8.3 format of the name, so it will be something like "c:/progra~1/micros~1/vc7". Use "dir /x" at an MS command prompt to see the 8.3 format of each directory. Mark Quote Link to comment Share on other sites More sharing options...
fragger Posted July 25, 2006 Author Share Posted July 25, 2006 Hi, thanks for your replys unfortunately I could not fix it. I ran the vcvars32.bat and changed the path to: F:/PROGRA~1/MICROS~1.NET/Vc7 , but there are no changes on the output... hmm I'm re installing Visual Studio now, maybe there are some problems since I had the 2005 version installed before... Damn still the same..this is getting realy annoying , i'v got no idea whats wrong.. Quote Link to comment Share on other sites More sharing options...
fragger Posted July 27, 2006 Author Share Posted July 27, 2006 Yeahh it works now i think there was a space between the pathes in the PATH environment variable Quote Link to comment Share on other sites More sharing options...
TheUsualAlex Posted July 27, 2006 Share Posted July 27, 2006 Yeahh it works now i think there was a space between the pathes in the PATH environment variable Hey Fragger, thanks for the note on that. Just out of curiosity, VS2005 worked with the HDK8.1 now? Thanks! Quote Link to comment Share on other sites More sharing options...
edward Posted July 28, 2006 Share Posted July 28, 2006 No, you still can't. Notice how it's "vc7" in the path. Quote Link to comment Share on other sites More sharing options...
TheUsualAlex Posted July 28, 2006 Share Posted July 28, 2006 No, you still can't. Notice how it's "vc7" in the path. Thanks Ed. : ) I asked because somewhere in the thread I think he mentioned about 2005 version, hence I asked. : ) Quote Link to comment Share on other sites More sharing options...
