Noise loses sharpness when animated?
Hi!
I have a problem with my animated sharpy noise. It loses it's sharpness.
Anyone got any idea how this can be? As far as I know I don't have motion blur activated..
Here is the hip if you want to take a look: noisewWthTime.hipnc (the same noise is applied as an embedded digital asset in both the sop)
Thanks for the help. :)
  • 1 month later...
Coming back to this, @anim :
This doesn't seem to work when I am directly working at mat-level and choose "Subnet Connector" as scope on my 'time' parameter, inside the noise asset and fill in $T on the asset instance. The noise is sharp then in the Render, but it doesn't move.
This is a problem for me right now, because when I collapse it all into a material builder I can't seem to properly apply the other shaders in that material builder (that are not connected to the output_collect) and which also use other VOPs in that material builder.
Short: I would like to have it all in one place, so I hope there is a trick to make this work on asset level in /mat. :)
Edited by Krion
If there is no answer why $T won't work in an asset in /mat while it does work on a material(builder), I would at least wonder why the appliance of materials inside a builder doesn't give the same result as they do if they are located at /mat.
See here. Displacement and Colormix don't work when they are inside a materialbuilder:
Is that was possible that would also provide a solution for me.
Anyone?
Edited by Krion
Check at this end of this dicussion
"So in materialBuilder context the displacementBound of the principled Shader don't work and you must use a mantra propertie !"
Not sure but I suspect is the same kind of problem.
Hop this help.
