Fluid Particles Surfaces flickering
Willms
Hi everyone.
I'm tried to Melt a statue following this tutorial *, but, I don't know for what reason when calculating cache the surface geometry makes flickering in all parts of the model, even in parts where the points don't move.
Melt.gif.ad751163989797348bbd797e447a7a35.gifFlickering1.gif.2d1af3b7031d1567c75320218b9f4f48.gif
My intention is to create a VAT to sending to Unreal Engine 4, but when I import the model and texture, the result is equal, flickering on geometry ... any idea for why can this happen?
These are my parameter in "flipfluidobject":
Best regards and thank you so much. :)
* Tutorial:
Edited by Willms
On flipsolver you have reseed tab, there you have temporary particle count on each voxel. That one helps you with getting mesh smoother, especially with high viscousity fluids.. If you pump up Particle per voxel parameter, it should solve your issue. Enjoy! :)
Edited by ItsMeM
