adametheridge80@gmail.com Posted October 4, 2019 Share Posted October 4, 2019 Hi Guys. I'm trying to create a kind of 'expanding foam' effect (like an Elephant's Toothpaste chemical reaction). Expanding out of a teacup. But my FLIP fluid is hitting a weird shelf and not overflowing the edges of the cup properly (see below). My emitter is a sphere at the bottom of the cup. .hiplc file also attached. Any pointers hugely appreciated. Elephant_Foam_02.hiplc Quote Link to comment Share on other sites More sharing options...
catchyid Posted October 4, 2019 Share Posted October 4, 2019 hi, I have not checked your file, but from the image, it seems either : (1) you a collision volume that prevents liquid from falling down, (2) the bounds of your flip simulation is somehow limited to minimum height (I doubt it as I can see fluid inside the cup). Another point: it might be also possible (and even produce better results) if you use SOP to create such effect, meaning, spheres getting bigger then burst, and mesh that geo. If you manage to do it on SOP, it will be faster and easier than using divergence field. Quote Link to comment Share on other sites More sharing options...
bunker Posted October 4, 2019 Share Posted October 4, 2019 the solver is expecting an SDF so you need to use the 2nd output of the collisionsource1 SOP. Quote Link to comment Share on other sites More sharing options...
