I have problem with paint node. its not following the animation of the mesh
awie12
Hi how to make the paint follow to the animation of the mesh. as you can see to this image on the next frame the paint is destroyed. please help thanks. is there any attribute wrangler to make it follow.
Edited by awie12
you should animate a geometry after Convert VDB node, then paint it.
Just now, vicvvsh said:
Hello
I am using alembic file then convert it to vdb. i try painting before converting it to vdb. and its works but some how after converting it to vdb the paint is not following and breaks like in the pictures
