philpappas Posted October 6, 2019 Share Posted October 6, 2019 I have this expression to choose from a set of numbers randomly. (1,2,3,4,5,6....49,50) floor(rand($PT*ch("seed"))*detail("../node/","total",0)) My problem is that out of 50 numbers that i have only 23 make it after the expression. How can i make sure every number gets picked? Quote Link to comment Share on other sites More sharing options...
Atom Posted October 6, 2019 Share Posted October 6, 2019 I don't think I would use a floor for that. Maybe try... int rnd_index = int(fit01(rand(@ptnum+ch("seed")),1,50)); The nature of random numbers is that you might not get all 50 variation, while processing 50 points. To achieve that consider randomizing a list/array and using the point number as an index into that list. https://www.sidefx.com/forum/topic/52579/?page=1#post-236406 Quote Link to comment Share on other sites More sharing options...
ThomasPara Posted October 7, 2019 Share Posted October 7, 2019 i guess int is rounding to nearest integer, while floor will allways go down. //floor i@rnd_value = int(floor(rand((@ptnum+1)*(chi("seed")+1))*chi("range")))+1; //rint i@rnd_value = int(rint(rand((@ptnum+1)*(chi("seed")+1))*chi("range")))+1; Quote Link to comment Share on other sites More sharing options...
philpappas Posted October 7, 2019 Author Share Posted October 7, 2019 thanks a lot for the pointers! i will try both when i find time and get back to you On 10/6/2019 at 8:20 PM, Atom said: To achieve that consider randomizing a list/array and using the point number as an index into that list. Expand that is actually a very good idea Quote Link to comment Share on other sites More sharing options...
