Curl Noise functions in voplib.h
Poetsofthefall
Ahoy there!!! A quick question...
I'm writing VEX noise functions but is a bit confused with Curl Noise functions. It's not like that I didnt get it. Of course I get it but is stuck in this weird functions in voplib.h. Here's what I'm stuck with....
Down below is the Code. why is xDiffNoise yDiffNoise and zDiffNoise there anyways. I couldnt find a function that's making use of it. Maybe I'm missing some. But please somebody explain it to me. Just to say... I'm writing a Curl Vex Function with all the Noise options.
Thanks.
noisevec = onoise(pos*freq - offset, turb, rough, atten) * amp;
    xDiffNoise = onoise(xDiff*freq - offset, turb, rough, atten) * amp;
    yDiffNoise = onoise(yDiff*freq - offset, turb, rough, atten) * amp;
    zDiffNoise = onoise(zDiff*freq - offset, turb, rough, atten) * amp;
I'm pretty sure you'll find where they are used if you search voplib.h for them again
Edited by anim
float eps = chf('epsilon');         // Default 0.01
float magnitude = chf('magnitude'); // Default 1.0
vector p = v@P;                     // Noise Initial Position
float freq = 1.0;                   // Noise Frequency
vector offset = chv('offset');      // Noise Offset
p = p * freq - offset;              // Final Noise Position
vector dx = {0, 0, 0};  dx[0] = eps;
vector dy = {0, 0, 0};  dy[1] = eps;
vector dz = {0, 0, 0};  dz[2] = eps;
vector fxdxn;   vector fxdxp;   vector fxdyn;
vector fxdyp;   vector fxdzn;   vector fxdzp;
// Evaluate the noise in a local neighborhood for finite differences
fxdxn = noise(p-dx);    fxdxp = noise(p+dx);    fxdyn = noise(p-dy);
fxdyp = noise(p+dy);    fxdzn = noise(p-dz);    fxdzp = noise(p+dz);
// Compute curl from the cross product
vector curl;
curl[0] = (fxdyp[2] - fxdyn[2]) - (fxdzp[1] - fxdzn[1]);
curl[1] = (fxdzp[0] - fxdzn[0]) - (fxdxp[2] - fxdxn[2]);
curl[2] = (fxdxp[1] - fxdxn[1]) - (fxdyp[0] - fxdyn[0]);
float scale = magnitude * (1.0 / (2.0 * eps));
curl *= scale;
@P += curl;
If it's helpful, here's what a basic curl noise function looks like.
You could replace the noise() calls with whichever scalar noise you prefer.
vector curl;
curl *= scale;
@P += curl;
Will check it STRAIGHT AWAY. Thanks many lot.
