if in list (vex)
gerardocastellanos
I stored different index (integer number) in my primitives, and I want to create an array detail attribute with all my different index.
sometimes my geometry could has 4 different index, for example (3,6,7,2), but in another case it could has 6 or 8 different numbers.
my idea is store in a detail attribute that list of numbers (index)
I create an primitive wrangle with this:
int indexList[] = detailattrib(0, "indexList",0,1);
if (!find(indexList, @index)){
push(indexList, (int)@index);
setdetailattrib(0, "indexList", indexList);
but it does not work as I expect.
what I am doing wrong?
thanks
Edited by gerardocastellanos
as I mentioned if returned index by find() is negative it's not found
your test simply tests if it's 0, which is actually still a valid index
so you want to do :
if (find(indexList, @index) < 0)
Edited by anim
