wreath Posted October 16, 2019 Share Posted October 16, 2019 Hey guys, I usually use either point velocity or trail sop to calculate speed, when your animation starts at frame 1 and you have a cache starting at 1, it causes first frame to be missing (i know it requires a frame before to calculate speed) its easy to cache +1 frame earlier then global animation start but what i want to ask is if there is any simple solution for already cached files? Quote Link to comment Share on other sites More sharing options...
StepbyStepVFX Posted October 16, 2019 Share Posted October 16, 2019 If the movement is smooth enough (ie. low acceleration), and geometry being consistent from one frame to the other (no deletion of points or particles, or reordering of point numbers), you could get the vel for the first frame by copying it from the second one, and then keep the trail sop results : - plug your Trail SOP to compute vel. - use a timeshift node to get the second frame (or $F+1) - transfer the vel of the time-offseted stream to the initial stream (with point wrangle, plugin the cache in first input and the timeshift in second input, with the code v@vel = point(1, "vel", @ptnum);) - use a switch node to take the first frame on the point wrangle, and the remaining frames from your cache (you could also put an if statement in point wrangle : if ($Frame == 1) { v@vel = point(1,"vel",@ptnum);} 1 Quote Link to comment Share on other sites More sharing options...
wreath Posted October 16, 2019 Author Share Posted October 16, 2019 Brilliant! thanks Quote Link to comment Share on other sites More sharing options...
