Clustering does not connect individual objects
wreath
12 minutes ago, 3dome said:
not sure if that option exists in other versions but in 17.5 it's at the bottom of the voronoi fracture
I see, yes Voronoi has that option but i am using material fracture sop in the scene and it does not so i kind of need a manuel solution for this
Tried everything but cant make it work so it would be great if someone can edit the file i upload. Basically i would like to be able to use material fracture + cluster sop but also able to cluster individual objects together and have intra cluster and cluster to cluster groups output.
On 23.10.2019 at 12:58 PM, 3dome said:
If the pre-build nodes don't give you what you need, like i said, build it yourself.
This file is by no means the best solution, but it gets the job done.
dm_Cluster_Individual_Problem_01.hip
Sorry Dominik I was buried at work just been able to check the file thanks a lot for your time and help! :)
