RustyMac2020 Posted October 24, 2019 Share Posted October 24, 2019 Hi all I am currently working on a feasibility test in order to build up some understanding of procedural modelling, I have a question regarding expressions in Houdini today, I have received great help from artists in the community which I am very grateful for, thus has helped me get this far, the new question I have is, I would like to delete all the lampposts based on the location of a building box I am using to represent a futuristic house, this box will be a model of a house and will have details like windows and doors later on, with this in mind, am I better of using a proxy box over my model which deletes the lamppost inside the box's radius or is this possible with the actual asset itself?, I have attached an image of what I mean including the current expression within the delete node thank you . Kind Regards Ahmet.B Quote Link to comment Share on other sites More sharing options...
jeremiah Posted November 2, 2019 Share Posted November 2, 2019 Hey Ahmet, is your lampposts copied to a template of points? If that's the case, simply use group sop to group points with object ( your "building box") and delete points by its group. Cheers, 1 Quote Link to comment Share on other sites More sharing options...
RustyMac2020 Posted April 22, 2020 Author Share Posted April 22, 2020 On 02/11/2019 at 11:52 PM, jeremiah said: Hey Ahmet, is your lampposts copied to a template of points? If that's the case, simply use group sop to group points with object ( your "building box") and delete points by its group. Cheers, Hi Jeremiah; sorry for the late reply, I managed to sort it out. I wanted to learn a bit of programming hence why I chose this weird way of producing the same result. Thank you for your input it is well appreciated. Quote Link to comment Share on other sites More sharing options...
