Nour Almasri Posted October 30, 2019 Share Posted October 30, 2019 Hi , I have a houdini hda that generating some poly data , but the normal of the poly is weird , i tried to add a normal sop as point or vertex in houdini with different face angle inside my hda , but still can't get a good normal ? I tried also to change the setting for the hda in maya interface (“preserver mesh locked normals”) , but it didn't help . I attached an image to the result i get in maya to show the problem , if i load my hda in cinema 4d , it's give me a good poly normal by default ! Is there any solution to get a sharp or good normal ? any help is appreciated . Quote Link to comment Share on other sites More sharing options...
Nour Almasri Posted October 31, 2019 Author Share Posted October 31, 2019 I get answaer in side effect forums , just in case someone face this issues . https://www.sidefx.com/forum/topic/70016/?page=1#post-297402 Quote Link to comment Share on other sites More sharing options...
