Librarian Posted November 17, 2019 Share Posted November 17, 2019 For someone like me that has 16.5 Houdini (old computer can't have 17.5) is it possible to run on the mentioned version. can't figure it out points(group ) and split. (or I just missing something) file from 16.5 physarum_2d_01Error.hipnc entagma https://entagma.com/physarum-slime-mold/ Quote Link to comment Share on other sites More sharing options...
flcc Posted November 18, 2019 Share Posted November 18, 2019 it seem in H16 the * syntax in the group sop, not work, or don't work the same. just remove it (this will select all the points). This way the file sort of work. The second problem seem to be the Volume rasterize particle sop. it's not the same in H17+ I'm attaching a capture so you can see and the "semi-working" file physarum_2d_01Error b.hipnc 1 Quote Link to comment Share on other sites More sharing options...
Librarian Posted November 18, 2019 Author Share Posted November 18, 2019 Thanx Fred Quote Link to comment Share on other sites More sharing options...
Librarian Posted November 18, 2019 Author Share Posted November 18, 2019 Salute @flcc Entagma and mxsage 1 Quote Link to comment Share on other sites More sharing options...
flcc Posted November 24, 2019 Share Posted November 24, 2019 (edited) Nice. I do the entagma tutorial and I can see why the H16 version was "approximative", like blurry. This time, the set-up is very close to the H17 version. In fact this set-up is very sensitve and for some parameters the range for tweaking is very thin. Tweaking just a bit I get some free spermatozoons. Very biological set-up physarum_2d_01 H16.hipnc Edited November 24, 2019 by flcc 1 Quote Link to comment Share on other sites More sharing options...
Librarian Posted November 24, 2019 Author Share Posted November 24, 2019 (edited) Thanx Fred for your time Combine and have endless fun https://wordpress.discretization.de/houdini/home/advanced-2/advection-in-fields/ https://github.com/mattebb/hda Edited November 24, 2019 by Librarian Quote Link to comment Share on other sites More sharing options...
