benne5 Posted November 22, 2019 Share Posted November 22, 2019 How do I get the material node to read the shop_material name from the object merge.( I don't want to directly path to the same material in the material network, but get the material name from the object merge) I've been looking into prim attribute scripts and @shopmaterialpaths, but I can't seem to get this to work. Any help would be much appreciated! Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted November 23, 2019 Share Posted November 23, 2019 13 hours ago, benne5 said: How do I get the material node to read the shop_material name from the object merge.( I don't want to directly path to the same material in the material network, but get the material name from the object merge) I've been looking into prim attribute scripts and @shopmaterialpaths, but I can't seem to get this to work. Any help would be much appreciated! You can use attribute transfer sop or attribute expression sop for this get_mat.hipnc 1 Quote Link to comment Share on other sites More sharing options...
benne5 Posted November 26, 2019 Author Share Posted November 26, 2019 Brilliant. Thank You. Quote Link to comment Share on other sites More sharing options...
