Random timeshift on the points, CopyToPoints
saca
7 hours ago, saca said:
hi,
I create test scene, Random timeshift on the points.
I have read some tutorials, "CopyStampSOP" and timeshift.
"CopyStampSOP" version is good well.
similar SOP "copyToPointsSOP", it's fail.
What expression should I write for timeshift?
thanks
Time_Shift_Random_v002.hipnc
Hi.
you should use for each point loop with copy to points sop and in the timeshift sop write point() expression to get your "offset" attribute. As number of point in this case will be number of loop iteration.
Time_Shift_Random_v002_01.hipnc
And thanks to toadstorm we have this nice blog's page: A Long-Winded Guide to Houdini Instancing
