davidyannick Posted November 24, 2019 Share Posted November 24, 2019 I have a little problem with normal I like to copy a piece on each point of a line but they are always reversed any idea ? Ii'd like the final pieces to be placed like if I applied a mirror but only with normal if it's possible arms.hiplc Quote Link to comment Share on other sites More sharing options...
Noobini Posted November 25, 2019 Share Posted November 25, 2019 well it's not reversed, it's aligned to the normals. However you set up your template piece facing Z, that will be aligned to the N. But why not think differently ? Just do your copy to just 1 'side'...once you're happy, then apply mirror, simple. You can quickly test this out by in copytopoints>target Points just say 0 so it copies to just the 1st point....then mirror. Quote Link to comment Share on other sites More sharing options...
