AntoineSfx Posted November 26, 2019 Share Posted November 26, 2019 I have a bunch of points and polygons, and I need to build faces so that the points on the curves are referenced (not just snapped to at build time) Using polydraw, I can't achieve this because it is not a procedural tool. Is there something that would work like Curve SOP using an input, and referencing points from the input with pn ? I guess I could do it with a chain of Curve, then somehow build quads, but it's a manual procedure and it's tedious. Quote Link to comment Share on other sites More sharing options...
anim Posted November 27, 2019 Share Posted November 27, 2019 (edited) you can use Poly Draw procedurally if you never commit any edits which may mean that you do the edits using the parameter pane instead if using viewport state which I think always commits the edits alternatively you can use other tools like Skin SOP, or just build your geo using Poly Draw interactively once and then live Attrib Copy P from the curves, etc... live_polydraw.hip Edited November 27, 2019 by anim Quote Link to comment Share on other sites More sharing options...
AntoineSfx Posted November 27, 2019 Author Share Posted November 27, 2019 (edited) I assume you typed the raw data manually in live_polydraw / raw data ? Edit:** ok, so I see you' re using one edit per quad. This is the tedious part I wanted to avoid. Also I have difficulties creating new faces when there is a polygon merged into the geometry. It won't snap to certain points for some reason that I don't understand.** This is actually the solution I had in mind, if that part was done in the viewport interactively (maybe it is but I can't really replicate it). The other solution (baked polydraw) is interesting too, and this is probably the one I'm going to use. Thanks. Edited November 27, 2019 by AntoineSfx Quote Link to comment Share on other sites More sharing options...
