crowd test transitions
isah_voodoo
Hello,
I am trying to get my transition graph to work. I want to go from "idlle" to "idle_to_walk" to "walk".
I am trying to follow the crowd example from the shelf but I still can't seem to get it going.
I have successfully simulated and randomized my clips in dops but i'm not sure how to get the transitions to work properly in h17
I will attach my scene file for anyone that wants to take a look
Thanks
h17_crowd_rd.hipnc
If you look at the transition graph, there is no connection between "idle_3" and "idle_to_walk" - so that transition is not possible. Thats why it doesnt work.
To get the best results I would turn off "Compute Transition Graph" on the Agent Clip Transition Graph SOP, and set up all the transitions manually (clicking the + for Extra Transitions).
@Skybar
Thank you for the response. I am trying to do it without the crowd transition graph and I am getting very strange results. I have linked up the crowd state names inside the crowd transition node properly i think. I was using the stadium example as a guide. Not sure why this is happening...
Thanks
h17_crowd_rd4.hipnc
