Point selection one in two
nemsi
Hi guys,
I can't get solution although it seems easy.. :) I would like to select point one on two but even with '(@ptnum+0)%2==0' (for odd id) or 'grouperange' sop I can't get the result i want.. (picture)
Can someone show me the way?
Thank you
Nems.
a bit experimental approach is using an integer point attribute (which initialized with 0 for one point) to grow over the whole geometry. Each time the selections growths the attribute increases by one. This will have the effect, that the neighbours of point 0 will have value 1 and their neighbours value 2 and so on. Using this attribute modulo 2 should give you the desired result. But this approach is a bit time consuming.
point_selection.hipnc
