If / Else group - VEX
jackassol
I'd like to know the best way to use If Else type statements in Vex code.
What I wanted to achieve:
if( in the group name "inside") {
    @stiffness = 1;
else ( not in side the group name "inside") {
    @stiffness = 1000;
What's the correct vex code for this function Vex?
I don't get this working.
best
jack
while there are functions like inprimgroup() or inpointgroup(), whenever possible I like to use the shorthand @group_groupname syntax. So if you run over points and are looking for a pointgroup then your code would be
if(@group_inside)
  	f@stiffness = 1;
else
  	f@stiffness = 1000;
Edited by 3dome
