adaptive polyreduce: more polygons where there is more detail
anicg
on a more realistic geo, I found it more tricky than using a simple height. Here's Tommy as the test subject, I guess the more highly detailed an area...the area would be smaller so that's what I used. It then has to be complemented to get it to the 'larger' values and also to make it easier on the eyes I mult it by 1000.
So if you scrub % here you'll see the larger areas being decimated before his face is touched.
vu_polyreduce_retention2.hiplc
Edited by Noobini
