Snappy_Darko Posted December 12, 2019 Share Posted December 12, 2019 Hi, the usual way of selecting one edge then pressing shift, then on the same line, but further away, clicking on an edge and all the edges in between get highlighted has stopped working. It's pretty odd and is making selecting along subdivided objects almost impossible..could someone suggest why this has started happening (I'm guessing I accidentally turned something off - though have restarted Houdini and it's still happening). Thanks Quote Link to comment Share on other sites More sharing options...
anim Posted December 12, 2019 Share Posted December 12, 2019 (edited) 28 minutes ago, Snappy_Darko said: the usual way of selecting one edge then pressing shift, then on the same line, but further away, clicking on an edge and all the edges in between get highlighted has stopped working I don't recall such behavior by default the usual way is to hold A not Shift to select partial or full loops it should also show up in the viewport hint text at the bottom of the screen Edited December 12, 2019 by anim Quote Link to comment Share on other sites More sharing options...
Snappy_Darko Posted December 12, 2019 Author Share Posted December 12, 2019 Your absolutely right, id not used Houdini in a while and had forgotten. Thanks for clarifying this. Quote Link to comment Share on other sites More sharing options...
