Render settings - glass, water, volumetrics [redshift]
Created kind of a render torture test. All that is missing is caustics!
Would appreciate some expert RS feedback on some starting settings to try for a quality render. Assume I will be enabling motion blur on the water droplets as well.
In this simple scene are there any advantages to setting samples at the Material level (water, glass)?
Using 2 Dome Lights, a Volumetric Spot and slight accent with backlight area.
glass_water_volumetric.mp4
Edited by art3mis
In this kind of scene just use global settings. No need to go too high.
4 64 or 128 could be ok.
As the scene is dark, set adaptative error threshold to 0.005.
Eventually if the Volumetric spot is two noisy, cranck up the volume sample in the light. 512 or 1024.
For caustics I never use it. But take a look at the doc here. It's very well explain.
by the way your sample movie is a bit small to be able to see nois artifacts and/or give advice.
OP
Edited post to include 2 images.
Getting a lot of noise and fireflies in the reflections.
Again 2 dome lights
1 volumetric spot with 1024 samples ray contribution
Uniform Settings
16 min
512 max
Adaptive error .01
Sample Filtering Gaussian
2,4,4
GI disabled.
With 16-512 samples, getting so much noise, It means that there is something wrong.
It seem the noise come from volume.
Is this sample setting is the one in the volume tab of the light (not the main one) ?
Fireflies is the worst problem. Very difficult to get rid with just render settings.
Better to find what trigger them.
If you can "frozen" one frame, I cant take a look.
Edited by flcc
