How to create a geometry parameter in own function?
Christoph_H
how to create a geometry parameter in own function?
In this example the parameter „geo“ should be read a string or an integer. How is this possible?
Because the point function can also read a string or an integer.
function vector TEST (string geo or int geo) {
    vector Ret = point(geo,"ABC",10);
    return Ret;
Possibility 1: v@R = TEST("op:../wrangler1'');
Possibility 2: v@R = TEST(1);
Edited by Christoph_H
you can overload your function with both possibilities by creating 2 or more functions with the same name but different artument types, amounts or even different return type
vector TEST (string geo) {
    return Ret;
vector TEST (int geo) {
    return Ret;
Edited by anim
well yes and no, obviously you don't want to keep duplicating your function just to change the type
so you can define your functions using pre-processor macros which can be more compact even though a bit ugly
#define F(TYPE) \
vector TEST(TYPE geo) { \
    vector Ret = point(geo,"ABC",10); \
    return Ret; \
F(int)
F(string)
#undef F
  • Like 2
as that page mentions:
Quote
The pre-processor supports many of the usual C Pre-Processor directives
so maybe search web for countless examples of C Pre-Processor directives
also have a look here:
$HFS/houdini/vex/include/
for some examples implemented by SESI, one of them is for example subdcurve.h
