Allegro Posted August 18, 2006 Share Posted August 18, 2006 Does anyone have any suggestions in particular how to texture an l-system based tree? My problem is that I've been reading The Algorithmic Beauty of Plants, and while the silhouette of my trees are alright, they quite distinctly still look like polygonal trees. Where branches happen, it's still quite obvious, and I'm not sure how to make these look -good- Additionally, does anyone know the best way to incorporate roots into the system? Quote Link to comment Share on other sites More sharing options...
Andz Posted August 19, 2006 Share Posted August 19, 2006 Hi Allegro, On the tube options, use a value other than 0 for the branch blend. Nice textures you have there. Quote Link to comment Share on other sites More sharing options...
Jason Posted August 19, 2006 Share Posted August 19, 2006 Also try looking at the PolyWire SOP. This SOP is designed to read attributes that can be generated by the LSystem SOP. Quote Link to comment Share on other sites More sharing options...
3__ Posted August 20, 2006 Share Posted August 20, 2006 ... Quote Link to comment Share on other sites More sharing options...
Allegro Posted August 21, 2006 Author Share Posted August 21, 2006 Quote On the tube options, use a value other than 0 for the branch blend. I had tried that, I was getting rather gross mutations with it, in the example picture that I had posted, it was closer to .1 than to 0 Quote Nice textures you have there. Thanks, I just quickly took some of the default rock ones from the library, I intend to get something better later, but just wanted to see if texturing made a difference as to how these things look. Quote Also try looking at the PolyWire SOP. This SOP is designed to read attributes that can be generated by the LSystem SOP. I had actually tried this, but going back to it today, I realize that I had forgotten to turn on point attributes... so when I used PolyWire, it did nothing with a skeleton, and obviously looked exactly the same when I used tube settings. With point attributes on, it's looking better. For roots, I've decided to go with a second l-system that's copied to the base of the skeleton rather than trying to incorporate it into the rules of a single l-system. It's looking a bit better now. I'll try to make a post with some decent trees once I've made some progress. Quote Link to comment Share on other sites More sharing options...
Andz Posted August 21, 2006 Share Posted August 21, 2006 Allegro said: For roots, I've decided to go with a second l-system that's copied to the base of the skeleton rather than trying to incorporate it into the rules of a single l-system. Since I'm a noob in Houdini and Lsys, I also prefer to do that... but separating twigs, branches, trunks... That is how I did this tree. Quote Link to comment Share on other sites More sharing options...
Allegro Posted August 22, 2006 Author Share Posted August 22, 2006 So you did a separate l-system for each element then? Quote Link to comment Share on other sites More sharing options...
Andz Posted August 22, 2006 Share Posted August 22, 2006 Allegro said: So you did a separate l-system for each element then? Yes, i did the twigs with leaves in one L-sys, then fead it into the leaf of the next L-sys, and so on... I just thoght it would be easyer to edit each part this way. Firts because of the equations and second because my machine is slow. Quote Link to comment Share on other sites More sharing options...
Allegro Posted August 29, 2006 Author Share Posted August 29, 2006 Does anyone have a suggestion as to how I could get some really nice dense foliage on the tree? The computer is only so good so I'd like to avoid simply raising the generations if possible. The tree looks pretty weak with simply a leaf at the end of each branch, but I don't know how to really fill out the tree unless I add tons of more branches. Is there a way to inherit the tropism with a scatter? I tried to scatter points along the l-system, and when I copied leaves on, they all pointed straight up... Quote Link to comment Share on other sites More sharing options...
Allegro Posted August 30, 2006 Author Share Posted August 30, 2006 I figured out how to instance (had never instanced anything before) so, it should be fine now. Quote Link to comment Share on other sites More sharing options...
michael Posted August 30, 2006 Share Posted August 30, 2006 that's a very nice looking tree.... my only crit would be the base of the trunk where it meets the ground...I don't think trees do that Quote Link to comment Share on other sites More sharing options...
Allegro Posted September 1, 2006 Author Share Posted September 1, 2006 arctor said: that's a very nice looking tree....my only crit would be the base of the trunk where it meets the ground...I don't think trees do that Thanks, I adjusted the shape of the roots. I'm personally pretty happy with it since before the 17th I'd never even really heard of lsystems. After doing the two different types of trees, I'm feeling pretty confident. I just wish I had a -really- good way to render... that tree takes about a minute to render right now with houdini's default lighting and render set-up... I'd like to be able to bring that time down a lot more... seems like trying to do a forest would bring my machine to a grinding crash. Then again, I don't exactly have the same type of machine that a company would use for rendering. Quote Link to comment Share on other sites More sharing options...
