CinnamonMetal Posted December 25, 2019 Share Posted December 25, 2019 I hope someone can help as to why my constraints are not working ? RBDConstraints.hipnc Quote Link to comment Share on other sites More sharing options...
kfu Posted December 25, 2019 Share Posted December 25, 2019 (edited) checked your file, you forgot to pack the geo also need to have a prim name before using connect adjacent pieces node. The dop also has some problems so I cleaned it up, hope it helps RBDConstraints.hipnc Edited December 25, 2019 by kfu Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted December 25, 2019 Author Share Posted December 25, 2019 @kfu I assumed I used the wrong solver ? How do you use the RBDFracturedObject ? Quote Link to comment Share on other sites More sharing options...
kfu Posted December 25, 2019 Share Posted December 25, 2019 (edited) 5 hours ago, CinnamonMetal said: @kfu I assumed I used the wrong solver ? How do you use the RBDFracturedObject ? Rigid body solver node is fine, it contains two types of solver in the node. But usually we use bullet for most cases so I just choose to use the bullet solver node. I never use the RBD FracturedObject, assume it the same with little difference,you can check Houdini document for it. Edited December 25, 2019 by kfu Quote Link to comment Share on other sites More sharing options...
