anicg Posted December 30, 2019 Share Posted December 30, 2019 (edited) This nodes seems too greedy and I cannot get anything out of it: It reaches the max RAM (32GB) very very quickly with very low res mesh, while with the same terrain a Convert Heightfield node gives me dense mesh. The maximum I can get out of it is what you see in the screenprint, (33000 polygons) completely useless, if I go higher than 0,03 in base density, it asks for more than 32GB RAM. While the detail is there and I get it with Convert Heightfield (16.7 million polygons) with no RAM issues. How do I get it to work: less density in the flat areas and more density in the detail areas? Edited December 30, 2019 by anicg Quote Link to comment Share on other sites More sharing options...
Mohanpugaz Posted October 7, 2021 Share Posted October 7, 2021 Hi Mate, Did you found any solution for this? ive been stuck with the same problem, curious to know if you get it solved. Thanks Quote Link to comment Share on other sites More sharing options...
