Attribute stamp not working
isah_voodoo
Hello,
I am trying to copy random voronoi pieces to my points
I created a random attribute on each point to use as my stamp:
i@rand=int(fit01(rand(@ptnum+234), 1, 46));
I am deleting each piece based of this attribute and feeding it into a copy sop. I made sure to put my rand attribute in the "Attribute stamps" parameter on the copy sop
I am not sure why Im still getting one piece copied onto the points.
Please help. Not sure I understand this well enough.
Thank you
rand_stamp_copy.hipnc
that's not even using a stamp function
if you put this into blast Group parm it should do what you expect:
@class=`stamp("../copy1", "rand", 0)`
however since you are using H18, you can directly use Copy to Points, rename rand into class and use class as a Piece attribute, can't post a file as I don't have access to H18 at the moment
