Blinn shader as default for new geos
On 1/4/2020 at 10:21 AM, konstantin magnus said:
Hi Andy,
if you don't get an answer here, it's mostly because you did not specify your question sufficiently.
Okay, i will try again.
When you create a surface object (like a box), it seems to have a default shader (is it phong?). I would like to change this. Whenever I create a surface object I want that houdini uses a blinn shader (material) for the surface or other shader with some custom set parameters. How can I achieve this? Thanks
  • 2 weeks later...
