StepbyStepVFX Posted January 11, 2020 Share Posted January 11, 2020 (edited) Hi All, The interaction between Crowd agents and FLIP simulation is one way : agents clearly influence the FLIP Simulation, but I have troubles to get the FLIP Sim move my ragdoll agents. I have already put the Feedback Scale to 1 under FLIPSOlver / Volume Motion tab / Solver. I have seen that particles interact with ragdoll agents, so I have created a POP object and added a POP Solver. The POP object is feed with the particles of the FLIP fluid at every simulation time. And I add a mass and pscale attributes to the particles. Now I have a better interaction between the ragdolls and the FLIP sim... but my agents now start to act as "spaghettis" under impacts of particles... I have tweaked the constraints (CFM, position CFM, position ERP etc.) but I can't enforce the position constraints and my ragdoll are really streched... Any ideas how to solve that ? Maybe a better way to make FLIP and crowd ragdolls better interact ? Any video / course / lesson / ressource where people have played with that a bit ? Thanks for your help crowdFLIPtest_v1.hipFetching info... Edited January 12, 2020 by StepbyStepVFX Quote Link to comment Share on other sites More sharing options...
StepbyStepVFX Posted January 13, 2020 Author Share Posted January 13, 2020 Any idea ? Quote Link to comment Share on other sites More sharing options...
Atom Posted January 13, 2020 Share Posted January 13, 2020 (edited) It does seem like the pop solution is causing the bad deformations. I disabled the pop section. I sorted the agents along the Z-axis. You may be able to automate triggering if they are in a linear order. Instead I took the hard coded approach which offers art direction. Place the Crowd Trigger node into Custom VEXpression mode. Use if statements to turn on the trigger, based upon individual point #s. // setting i@trigger to 1 will enable // setting i@trigger to 0 will disable int result = 0; // Stagger transition to ragdoll. if((@Frame == 13) && (@ptnum==0)){result=1;} if((@Frame == 15) && (@ptnum==1)){result=1;} if((@Frame == 17) && (@ptnum==2)){result=1;} if((@Frame == 28) && (@ptnum==3)){result=1;} if((@Frame == 29) && (@ptnum==4)){result=1;} if((@Frame == 31) && (@ptnum==5)){result=1;} if((@Frame == 37) && (@ptnum==6)){result=1;} if((@Frame == 39) && (@ptnum==7)){result=1;} if((@Frame == 42) && (@ptnum==8)){result=1;} if((@Frame == 46) && (@ptnum==9)){result=1;} i@trigger = result; For the ragdoll state, I dropped down a PopSteerSeek to make the agents move in the down stream direction. You can adjust the force on this node to match the agent speed to the fluid motion. ap_crowdFLIPtest_v1.hiplcFetching info... Edited January 13, 2020 by Atom 3 1 Quote Link to comment Share on other sites More sharing options...
StepbyStepVFX Posted January 13, 2020 Author Share Posted January 13, 2020 Many thanks Atom ! Quote Link to comment Share on other sites More sharing options...
