Semi regular parallel backup?
kleer001
While at a couple different studios (DD, FrameStore, DNeg) I think I correctly recall that they had a system setup on Linux where your smaller files (not caches) would be saved to daily in a ".backup" folder next to the folder being backed up
/usr/kleer/docs
would be regularly backed up in (I think)
/usr/kleer/.backup/docs
And is was like that for lots of directories. Or something like that. I can't exactly remember. And the search terms are so vague I can't find what this particular backup workflow is called. I can't even recall if they're on a separate disk or on the same disk as the original path.
This was really useful when trying to recover a mis-saved file or some other snafu and I'd love to implement it on my home machine, but what the freak is it?!
