Import Automate with String replace
Travis
Hi guys, I am trying to automate my alembic imports by using a string replace on my File path. For example: on my alembic File Name parameter I've written the expression -
`strreplace($HIP, "home/fx", "fx/waterfountain_v001")`.abc
I would like to be able to replace the version number with a wildcard so that it picks up the file regardless of what the version number is, but an (*)asterisk doesn't work. How should that be scripted?
Thank you in advance!
Thank you Alex. I don't think I need frame padding, as the alembic isn't a sequence. I am just wondering how to add a wildcard for the version number? I think the Alembic node in Houdini may not recognize wild cards though. Is that the case? Do you know a work around?
wildcards or simple expressions don't check files on disk so they will not go find what is the actual version in there (even then what would you expect if wildcard matches more than one file? )
path built by expression has to result in a specific file path that will be loaded if found
your best bet would be using python script that actually looks up the directory and finds the latest version for example
but rather than using it as a live expression it may be safer to have it as a menu script in a dropdown and then just reference picked value in your path expression, so that it doesn't have to check the disk all the time, just when the menu is invoked
Edited by anim
26 minutes ago, Travis said:
...The wild card would only grab the correct file, because there is only ever one file in that directory....
right, but I meant in general, if pattern matches more existing files it's a bit ambiguous, so yeah, with python you can make up the exact logic what would be looked for and picked
Edited by anim
