RBD Material Fracture Constraints Setup
StarryNight
Is your name attrib, all messed up. Either use a wrangle and add this line
s@name = sprintf("piece%d", @ptnum);
or after the assemble unpack your geo (Transfer the name attrib) > connectadjacentpieces
Edited by Sepu
Thank you for the reply and information, I had success using the second suggestion (utilizing the unpack after the assemble).  Can you explain to me why simply placing the unpack and transferring name fixed this.
Is it simply a matter of needing to make sure that attribute gets passed down the line?
