Ultraman Posted February 16, 2020 Share Posted February 16, 2020 (edited) hi ./ Is Possible in Chop Shift Group of channel by Id ? for example i have lot's bird , each bird have many Point with Motion and unique Id per Bird and i want push left to right the channel.. if checked the hip file can understand better Time Offset Objects Chop.hip Edited February 16, 2020 by Milad Savar ;) Quote Link to comment Share on other sites More sharing options...
hughspeers Posted February 21, 2020 Share Posted February 21, 2020 Hi Milad I would investigate doing this with the agent tools. Make your bird into an agent and then make a crowd of birds. There will be parameters to offset them in time with these tools. Or are you more interested in chops ? Thanks John Quote Link to comment Share on other sites More sharing options...
Ultraman Posted February 21, 2020 Author Share Posted February 21, 2020 32 minutes ago, hughspeers said: Hi Milad I would investigate doing this with the agent tools. Make your bird into an agent and then make a crowd of birds. There will be parameters to offset them in time with these tools. Or are you more interested in chops ? Thanks John hi , thanks for response . i never work with crowd tools.... i'm curios more chop stuff for learning , i want is break cycle pattern for my all bird (chop is faster and it's easy in stamp time shift and loop in sop but is so slow ) thanks Quote Link to comment Share on other sites More sharing options...
hughspeers Posted February 21, 2020 Share Posted February 21, 2020 Ok milad You could try and re-order and shift in Chops . this discussion - you could perhaps do the same but in sets of your_points * 3 . your birds have 12 points , so re order numerically then floor ($C / 48) perhaps. 1 Quote Link to comment Share on other sites More sharing options...
Ultraman Posted February 22, 2020 Author Share Posted February 22, 2020 13 hours ago, hughspeers said: Ok milad You could try and re-order and shift in Chops . this discussion - you could perhaps do the same but in sets of your_points * 3 . your birds have 12 points , so re order numerically then floor ($C / 48) perhaps. thank's a lot ... that's cool .. Quote Link to comment Share on other sites More sharing options...
