Follyx Posted February 23, 2020 Share Posted February 23, 2020 (edited) Is it still neccessary to put a facet sop with unique points followed by a prim sop with scale set to 0, after the constraint sop? Or isnt that urgent since H18? https://forums.odforce.net/topic/28679-cone-twist-constraint-relationship/?do=findComment&comment=162968 Edited February 23, 2020 by Follyx Quote Link to comment Share on other sites More sharing options...
anim Posted February 23, 2020 Share Posted February 23, 2020 (edited) it depends on the type of constraints you want to get for Glue is not necessary for others it likely is as most of the time you want those to have 0 rest length to begin with for fractured geos or touching pieces you may be able to use RBD Convert Constraints to Face, but if your resulting constraints are not 0 length you may still want to scale them to 0 Edited February 23, 2020 by anim Quote Link to comment Share on other sites More sharing options...
Follyx Posted February 25, 2020 Author Share Posted February 25, 2020 thank you Quote Link to comment Share on other sites More sharing options...
