underscoreus Posted March 1, 2020 Share Posted March 1, 2020 Hey guys, I am trying to store some variables into the session source so I can easily get at it at any time. So far the tests I've been running have been working great, but I am not quiet sure how I can expand on the syntax to allow for variables to control the values set into the source. This is the syntax I've used so far: hou.setSessionModuleSource("variablename = 0") However, as far as I've been able to figure out this will only allow for hard coded values, I am looking to insert the value from a variable instead of a hard coded value, like this: mynum = 3 hou.setSessionModuleSource("variablename = mynum") When I try this in the python shell I get the error back that "name 'mynum' is not defined" (along with some more text, most notably of which I guess is that it says the operation failed). Do you guys have any tips on how I could make this work? Sorry if this is very basic, I've been trying to look around for specific syntax examples but I am having kinda a hard time finding examples of actual syntax for the Houdini specific python commands. Thanks for the read! Quote Link to comment Share on other sites More sharing options...
underscoreus Posted March 1, 2020 Author Share Posted March 1, 2020 And having slept on it I just found a solution to my own problem. I don't know if its the most elegant solution, feel free to add other solutions if you guys have any because mine feels like a cheat. myvarname = 'variablename' mynum = 3 mystring = myvarname + ' = ' + str(mynum) hou.setSessionModuleSource(mystring) Essentially boils down to just creating the entire string before passing it into the setModuleSource command. Thanks for the read! Quote Link to comment Share on other sites More sharing options...
