Bound Radii
Noobini
FYI,
the Radii Attribute in bound maybe useful in some cases...but it's a bit annoying to access it in a wrangle...here's how:
The working wrangle is where I got it to work, the others were for reverse engineering.
Is there an easier, more obvious way? (I'm preparing to facepalm...)
vu_radii.hiplc
Edited by Noobini
that's pretty common
you need to define the type of the attribute you are expecting to bind, if left ambiguous you'll get fallback value, the best guess or error
so for example:
vector r = detail(1,"radii",0); // will load detail attribute as vector as it's the only type you are dealing with
@P *= detail(1,"radii",0); // same, therefore it will multiply @P component wise
@P *= float(detail(1,"radii",0)); // will force detail to read as float so it will fall back to x component if "radii" is vector, therefore it will multiply @P by x component of radii
@P *= vector(detail(1,"radii",0)).y; // will force detail to read as vector so it will allow you to specify component as .y, therefore it will multiply @P by y component of radii
@P *= vector(detail("../A","radii",0)).y; // will not work, because you are missing op:
@P *= vector(detail("op:../A","radii",0)).y; // will work
// usually you may want to do this for clarity
@P *= r.y;
// also you can omit last argument in detail function overall
vector r = detail(1,"radii");
