Ramp interpolation
Noti
Although I don't expect to get an answer, I still want to ask:
what kind of base function is used for the B-spline interpolation of ramp panel in Houdini.
Because as shown in the figure below, the shape I draw with vex according to the B-spline basis function is basically the same as that of the convert node, but this result is different from that of the B-spline in the ramp panel. And i found that the curve shape of the ramp panel is better to use.
The biggest difference is the position of the extreme point of the curve. I drew it in blue.
So I would like someone to indicate what base function (or method) is used by the B-spline of the ramp panel in Houdini?
11 hours ago, anim said:
you can use PolySpline SOP
set Spline Type to BSpline
and First/Last CV count to 2
Hi, thanks.
It does achieve the same result as ramp, but what I want to know is what interpolation formula it uses (Bspline).
Because i want to use it outside houdini.
1 hour ago, Aizatulin said:
have you checked "De Boor's algorithm" ?
https://en.wikipedia.org/wiki/De_Boor's_algorithm
It seem to give similar result if you add 2 additional start and 2 additional end points.
The weights are all 1 and the knots uniformly distributed.
Here is an experimental file
deBoorTestC.hipnc
My god! You gave me a lot of inspiration.
Just add two more points at both ends.
Thanks a lot and share my code here, you can see some differ(want to buy you a drink haha).
deBoorTestC.hipnc
