Export Separate Objects Out Of Copy To Points Loop
I have a simple set up that is copying multiple files from a switch node into a copy to points loop and randomizing them. I would now like to export them out of Houdini so I can use them in my C4D Scene, however when I export them out they all come in as one object. Is it possible to export them out as one object, but when I open them in C4D they are split into sub objects by the file name I am using in Houdini? I have tried using an unpack node, but houdini is saying there isn't any packed geometry. Any insight or advice would be appreciated.
