flip reseeding dont interpolate but set to value
ino
is there some way to set certain attributes of reseeded flip particles to a value or to 0
or to know by some attribute which particles are created by reseeding
i constantly pumping in particles by my self so simply checking the id (its bigger the the originally created amount) wont work
i probably could create some routine to catch the seeded particles by recording the biggest id check how many particles i inject .... on each frame
but i wonder if there is a build in way i did not find till now
here is a simple solution without any solver tweaks:
- create a random int attribute per point and convert it to float:
f@r=int(rand(@ptnum)*1000);
eg: r = 153.0
- on the FLIP solver/reseeding/interpolate attributes, add the attribute r
- as a post sim process, you can compare the original attributes and interpolated ones, they will have a decimal value >0
eg: r = 154.462
if(f@r-int(f@r)>0)@Cd={1,0,0};
in practice, this isn't 100% perfect so you can use a vector attribute instead, have a look at the attached HIP
separate_reseeded_bunker_001.hipnc
  • Like 3
:) i had sort of the same idea
i have an attribute which indicates a group membership which is currently an int (1 or 0)
i basically just interested that i dont get additional of this kind of particles so i simply switch it to a float and anything isnt exactly 1 is 0
That is interesting. So, you could generate whitewater only on reseeded particles, if you separate them before the fluid_compress node. Or surface each set, a little differently.
Edited by Atom
