using len() in switch node?
hey all,
inside a sop solver on a switch node I'm trying to get the length of a string array and multiply it with another channel
right now the solver is overcopying objects:
I was able to get this to work comparing the values of two float channels but I can't get it to work with a string array since len() doesn't show up in that context? I tried reading the manual on vex contexts and cvex but it's a bit confusing. which context is the switch node parameter in? is it in sop context because the node was created in a sop solver or is it somewhere else entirely because I'm typing in a parameter textbox?
Edited by rbesca
  • rbesca changed the title to using len() in switch node?
expressions in parameters are by default Hscript expressions, optionally you can switch to Python, which can provide more power (at the expense of speed and amount of code) depending on the task
you can also precompute value as an attribute using VEX and then reference in the parameter using one of the Hscript expression functions (detail(), prim(), point(), vertex())
  • Thanks 1
