Houdini7 Posted March 14, 2020 Share Posted March 14, 2020 I am using the houdini engine with 3ds max and getting the following error when starting a session: "Could not create session with pipe name: Could not create session with pipe name: HEMAX_AutoPipeServer" it works when i start max with admin rights. it seems with admin rights the pipe can be opened. but when starting max with normal rights i get that error. someone has an idea, how one can resolve this? another question is how do you propagate a selection in max (edge selection) to the hda. it does seem not to work, the hda modifiers works on the whole object and not on subselection level. any ideas? thank you. Quote Link to comment Share on other sites More sharing options...
Houdini7 Posted March 15, 2020 Author Share Posted March 15, 2020 does no one use the houdini engine? it seems these are pretty basic questions. or runs everyone his account in admin mode (which is not the default)? to the second question. it seems there is no solution yet. i think one can add an input field (face indices vertex indices) to the hda and enter some index value in this field in max, which will work. but is cumbersome because you need all the indices from the selection. with scripts it can be improved. hope there will be a good solution in the future. Quote Link to comment Share on other sites More sharing options...
Noobini Posted March 15, 2020 Share Posted March 15, 2020 use H engine as normal user all the time...just works for me. Quote Link to comment Share on other sites More sharing options...
Houdini7 Posted March 16, 2020 Author Share Posted March 16, 2020 22 hours ago, Noobini said: use H engine as normal user all the time...just works for me. hmm interesting. Did you install 3ds max in normal folder (C:\Program Files\Autodesk\3ds Max 2020\)? Quote Link to comment Share on other sites More sharing options...
Noobini Posted March 16, 2020 Share Posted March 16, 2020 22 minutes ago, Houdini7 said: hmm interesting. Did you install 3ds max in normal folder (C:\Program Files\Autodesk\3ds Max 2020\)? yes, default folder...but Max 2018 (from memory, 2017 also worked fine) Quote Link to comment Share on other sites More sharing options...
Houdini7 Posted March 16, 2020 Author Share Posted March 16, 2020 8 minutes ago, Noobini said: yes, default folder...but Max 2018 (from memory, 2017 also worked fine) Do you have the same settings like me (especially this "Out of Process" setting)? Quote Link to comment Share on other sites More sharing options...
Noobini Posted March 16, 2020 Share Posted March 16, 2020 all same except my Houdin Env is not specified...it's completely blank. Both Max2017/18 Quote Link to comment Share on other sites More sharing options...
Houdini7 Posted March 16, 2020 Author Share Posted March 16, 2020 really strange. it does not make any difference when i clear the houdini env. not sure why houdini engine cannot open the pipe, when opened with a normal user. thank you. Quote Link to comment Share on other sites More sharing options...
Noobini Posted March 16, 2020 Share Posted March 16, 2020 also just FYI, I'm on Indie 18.0.348, win10 (I'm fairly certain when it first came out...17.5 and win 7 ? it just worked for me) Quote Link to comment Share on other sites More sharing options...
Noobini Posted March 16, 2020 Share Posted March 16, 2020 also my UAC is dragged down to deadset bottom level. Quote Link to comment Share on other sites More sharing options...
Houdini7 Posted March 17, 2020 Author Share Posted March 17, 2020 okay, this seems really strange now. when i start the session right after starting max (clear scene) it works. but when i start the session after loading a scene, it will not work! so now as a workaround: start a session directly after starting up max and load then your scene. really awkward. Quote Link to comment Share on other sites More sharing options...
Noobini Posted March 17, 2020 Share Posted March 17, 2020 mine works with clear scene or already loaded scene. Quote Link to comment Share on other sites More sharing options...
