exchange @ptnum? or change @ptnum
Hi,guys!
Is there a way to exchange two points' @ptnum?
I want to exchange pt0 and pt1's @ptnum.And don't affect the prim Normal direction.
setpointattrib(0,"ptnum",0,1,"set");
setpointattrib(0,"ptnum",1,0,"set");
They don't work.
Thanks.
44 minutes ago, anim said:
you can't directly change ptnum, but you can store it to an attribute, change that attribute and then use Sort SOP to sort by that attribute
Good idea!Thank U very much!It works.
Edited by Willex
44 minutes ago, animatrix said:
You need to use the Sort SOP and use your ptnum attribute but make sure every point has a valid unique number before swapping some.
In after anim :)
Thank U very much. It works.
Edited by Willex
