emilguder Posted March 19, 2020 Share Posted March 19, 2020 (edited) Hey guys, I am trying to create a workflow with which it is possible to embed texture image files in a FBX. I know that I will probably have to write a python script to do so. Maybe one of you has already done anything like that and could help me out? Regards, Emil Edited March 19, 2020 by emilguder Quote Link to comment Share on other sites More sharing options...
Johan Posted April 9, 2020 Share Posted April 9, 2020 I've build a post-render script in the fbx ROP. I export the file as name_temp.fbx and the script takes the name and builds the processing string. I've used the autodesk fbx exporter that's freely available. Here's the code in my HDA pythonModule that I call in the script field. def convertFBX(exe, tempfile, finalfile): # FBX_CNVRT = 'C:\\Program Files\\Autodesk\\FBX\\FBX Converter\\2013.3\\bin\\FbxConverter.exe' if exe != '' and tempfile != '' and finalfile != '': #print(arg) subprocess.call([exe, tempfile, finalfile, '/e']) if os.path.isfile(tempfile): os.remove(tempfile) #with open('Z:\\projects\\T3D_Scanner\\01_settings\\houdini\\convertFBX.log', 'a') as f: # f.write('{} : {}\n'.format(datetime.datetime.utcnow(), arg)) # f.close() else: print('Not enough args, need old name and new name') Quote Link to comment Share on other sites More sharing options...
