meerkat Posted September 12, 2006 Share Posted September 12, 2006 Hello, I need to convert a polygon object like a box into just its curves, like when its viewed in wireframe mode. How do i do this? Thanks in advance. amir Quote Link to comment Share on other sites More sharing options...
michael Posted September 12, 2006 Share Posted September 12, 2006 try the Carve SOP Quote Link to comment Share on other sites More sharing options...
kubabuk Posted September 12, 2006 Share Posted September 12, 2006 You can also try PolywireSOP or WireframeSOP - this use primitives (spheres and tubes) so with more complex things works better. K Quote Link to comment Share on other sites More sharing options...
sibarrick Posted September 12, 2006 Share Posted September 12, 2006 Or if you just want the lines use the ends sop and set it to unroll in U. Quote Link to comment Share on other sites More sharing options...
old school Posted September 15, 2006 Share Posted September 15, 2006 Ends SOP Close U set to "Unroll" Done. The Ends SOP is a bit of the Primitive SOPs functionality pulled out so you can also use the Primitive SOP. Primitive SOP Face/Hull folder Close U set to "Unroll" Quote Link to comment Share on other sites More sharing options...
mattd Posted December 14, 2006 Share Posted December 14, 2006 I needed something like this too a while ago, and the other options were not doing exactly what I wanted. I ened up using the wireframe to convert to tubes, then convert the tubes to nurbs. Then you can use the basis to extract any point you need along the length. it was slow and ugly, but it worked. I think it was a midpoint that I needed as well, and this method keeps the normals in a useful state MD Quote Link to comment Share on other sites More sharing options...
sibarrick Posted December 14, 2006 Share Posted December 14, 2006 Deja vu thread.... Quote Link to comment Share on other sites More sharing options...
shikung444 Posted September 15, 2007 Share Posted September 15, 2007 Hi, I just needed to do this and found out how. Use the Fit SOP. It is named strangely, but works most excellently. Quote Link to comment Share on other sites More sharing options...
